Atv stop running because of fuel pump so i change the fuel pump and the fuel injector and check the fuel pressure every thing check out ok so far.now i started the atv up and the idle was high so turn it off and check the idle air control vavle everthing seem to work ok and change the o ring crank it up again same thing idle still high check the iacv again still same thing can you help me out.
