I have a 2007 Honda Rancher 400FA. I haven't started it in a month and temps have been like 10 degrees and below at night. I tried to start it yesterday and it turned over good but wouldn't start. I tried it again for about 10 seconds still didn't start. I flipped the on off switch to make sure it was in on position. Now when you push start button it does absolutely nothing no clinking or anything. Its been hooked to battery maintainer whole time. Lights are good and bright the battery isn't dead or weak. Its still hooked to the tender. You push start and nothing happens. Neutral light is on. No fuses are blowed that I can see. I only see like 6 fuses near the battery compartment. Is there fuses other than in the fuse box by the battery? Any help is appreciated. Thanks!!!
