Ok so I have a 2006 400ex and it has a problem that I have done so much to try and fix and nothing has worked. When the bikes cold, it starts just fine. When the bikes warm, it starts rough. But that’s not all. When I push the throttle about half way the bike stutters and lags like it’s not getting enough fuel. (Mind that it does only when I’m putting around and half throttle). But the weird thing is that it smokes when I rev it hard like it’s running lean. Almost like it’s running lean and rich at the same time. This all happend after I adjusted the valves. The quad runs amazing at full throttle it’s just when I let off the throttle it starts bogging stuttering and begging for gas. And also after I ride it hard and go to stop it doesn’t idle and shuts off. Like I said it all happend after I adjusted the valves.
Whats done to it carb wise: 175 main jet, 42 pilot jet, needle was raised 1 click, carb was rebuilt which was recent, and that’s about it
It’s got the stock header pipe on it with a hmf slip on, no airbox with a k&n filter, 426 big bore, stage 2 cam.
I need help please let me know ASAP!!!!!
