Hi all, I have a 2006 trx250tm fourtrax with digital display. The neutral, reverse and oil temp light above the display works fine. The display is dead when I turn the ignition or or start the bike. However, I have been able to make it come i\on in 2 ways: Firstly by disconnecting the plug right under the display (9 wires). When I slowly pushes it back in it reaches a point where she comes on. Problem is that while holding it there, if I turn ignition off and back on again it doesn't come back on again. Secondly, if I remove the main 15A fuse near battery while ignition is on and push it back in, it comes on. Same deal, turn ignition key off and back on and no joy! Any thoughts? I have so far sprayed wd40 on the 9 wire plug. Not sure if that was a good or a bad thing? :smile
