Hello I am working on a 2006 Rubicon for a friend. The motor started giving trouble shifting and he was getting a temp warning light. When he shut the bike off it would not turn or pull over. I ended up removing the motor and completely dismantling it to find a 5mm bolt stuck in the oil pump. The bolt came from a divider inside the oil tank. Replaced the oil pump and put the engine back in.
Tried starting the engine today and no spark and the gear position does not read on the dash.
Looking for some help. Should the coil still spark without the neutral light being on
