New to the forum - came across this forum while researching my issue. Lots of good info on here.
- I have a 2006 Rancher 350 es
- Ignition fuse (10A) is blowing
- after blowing the fuse the neutral and reverse lights come on at same time ( posting this symptom because I found an older post where someone said it's not possible for both to be on at the same time)
- the gear indicator displays --
Saw a recent post from a member with a similar issue. The fuse would blow when shifting to 3rd. Mine has blown twice now and the 2nd time it blew I had just shifted to 3rd. I will test this today and see if the gear position has anything to do with it.
Hoping someone can help by pointing out a common issue known to blow the ignition fuse
Thanks in advance for any advice or help
HB
HB
