1 - 2 of 2 Posts
So I bought an '06 TRX 350 FE, Previous Owner replaced carb with Amazon unit, he's looking for the original carb, in the meantime most vacuum lines are pulled off so I'm looking for a vacuum line diagram, downloaded the factory service manual but can't find anything showing the vac lines. I don't know much about this type of carb but it appears vacuum lines very important so any advice is appreciated
They are not vacuum lines they are vent lines. Emission control and keeps out insects.
Download the service manual and check parts links in my signature block below. There will be info and diagrams you can use.
I wouldn’t use the aftermarket carbs because they don’t fit the choke and throttle cables very well.
Always buy OEM
1 - 2 of 2 Posts
