1 - 2 of 2 Posts
Hello all, my 2006 Forman starts and idles fine, but when you give it gas past half throttle in any gear, it cuts out badly. Doesn't stall, but sputters badly. If you let back off the throttle a bit it kicks back in. It does the same in neutral. New plug, no difference. Any ideas?
welcome to the forums, time to clean the carb, drain fuel tank, fresh gas, check to make sure fuel is filling carb bowl from tank ?. has it sat for long ?, can't let them sit, fuel today is worthless if it sits for long. air filter clean ?. when they idle, but won't rev ?, then this tells me carb issue :).
1 - 2 of 2 Posts
