Welcome to the forums. I agree with Shadetree, if the starter is turning, but it's not turning the engine over, then your one-way starter clutch bearing is out. It's not located behind the flywheel on the 450R, though, it's located behind the primary drive gear on the clutch (right) side of the engine.if you know your starter is good..then check your one-way starter bearing..it's behind your flywheel.
thanks for clearing that up helmut..i just learned something new !..lol...was half right anyway..lmfao.Welcome to the forums. I agree with Shadetree, if the starter is turning, but it's not turning the engine over, then your one-way starter clutch bearing is out. It's not located behind the flywheel on the 450R, though, it's located behind the primary drive gear on the clutch (right) side of the engine.if you know your starter is good..then check your one-way starter bearing..it's behind your flywheel.
