I got a great deal on an 06 350 rancher it runs and rider great but the front breaks dont work. I have replaced the master cylinder and the wheel cylinder seals all look fine i have tried bleeding the system tnd the wont get pressure. Any ideas? Thanks in advance!
Welcome to the forum.
The easy way to fix them where they'll last is to knock the top and bottom ball joint loose and swap 420 rancher disc brakes in place.
Otherwise, you'll need to free up the adjuster wheel on the drums and crank them out where they're barely dragging the drum, then see if you have brakes.
Drums aren't worth the effort on a machine that easily accepts disc brakes.
