Hello I have a rancher 350, 2005 model that came in with a complaint of Not ESing in reverse, but manual shift perfect.
Long story short, just needed the reverse cable adjusted, boom fixed!
The other issue and this one is confusing... Is there is no gear indicator. None, not even the famous "-" mark. There is literally NO activity in the top left corner of the combo meter. The meter is not burned up, everything else is perfect. Speed, time, miles/hrs. The screen is perfect. No burnt pixels or anything. Its almost like the meter is the wrong one from the factory, but customer said it was all original. Like its not even supported.
Just some obvious points here:
There is nothing wrong with the ES system. The gear position switch works (it knows where its at, or else the N and R light would not work, plus the ES would not work neither).
The angle sensor was replaced (OEM) before customer brought to me
Speed sensor works as should, and is accurate.
What I am getting at is, Yes... The TV is plugged in!
This ATV only has 60 miles on it since 2005, its in perfect condition. Always cleaned and shined up, dried off and put indoors after every ride. (Old man owned).
I will upload a picture of the dash of this ATV, and one of a "normal" same atv.
Weird!
Weird!
