Hello everyone,
I’m a newbe both to forums and to quads. I’m hoping to pick your brains a bit. I have this quad that when you start it cold it idles perfectly and shifts into gear without a whimper. I use it to plow my driveway which takes about a hour if you include my fun time. Today, I started plowing the snow and the machine was running flawlessly for about 30 minutes. I stopped at the end of the driveway to turn the blade and the idle started to rev. I blipped the throttle a couple times to see if it would go back to a normal idle. It didn’t so I shut the machine off and restarted it. I could hear the idle starting to rev again, so I blipped the throttle again, and when then Idle was at a low point, I slammed her into gear. I applied throttle and the machine wouldn’t move. I shut it off, went into the house pouting cause I enjoy plowing the driveway unless the wife notices. I let the machine sit in the cold for a couple hours. Then, I started it and drove it back into the garage. I let it run a bit, and the Idle started to rev again. Any ideas of what would cause this intermittent good quad, bad quad? I’m suspecting a possible ECM issue. Anyone heard of something like this?
welcome; your at the right place for picking at brains. unfortunately, mine have atrophied. how long ya had this bike, and is it the 1st. winter? seems like something is sticking..
maybe a vacuum leak, when it gets warm, or choke may be sticking.
