i have a 2005 honda fourtrax 350 and it was burning oil so i replaced the rings and gaskets and the valve seals are good it only has 90 psi compression i dont have a manual and need the rebuild specs any help would be greatly appreciated
Did you hone the cylinder? Also check the crank case breather and make sure there are no obstructions.Make sure your valves are set correctly
Valve adjustment procedure for Foreman 350 (all years)
ya i have them staggered i did not hone the cylinder should i of the bike only has 170 hours on it
do i have to put another set of rings in or can i use the other ones if i hone it. And does any one now the valve clearence measurement
