I have a 2005 foreman 500 ES and the problem I'm having is the left front end is sitting about an inch lower and the front tire is out at the top of the tire I'm not sure what could cause this to happen. I just changed the bearings, seals. I have looked at everything under it and dont see anything wrong I have even matched it up with the other side the ball joint have just alittle slack that seems normal any help on this issue really would help just something I could look for the bearings is about as far as I have been in the front end I did adjust the tow but it the lower front and the tire out at the top that is bothering me. Thanks so much
