Trying to get front drive shaft out of engine.Do you have to loosen front dif to get enough room to pull out ?
yes, you have to unbolt the front diff, yank is as far forward as you can, then push the drive shaft forward ( spring loaded ) off the output shaft until it clears it, then angle it, then pull it back off, and out of the front diff. be warned !, your gonna lose gear oil out of the front diff !.
Discussion Starter #3
Thanks,worked good.Got motor out and tore apart.need a head and jug.Any places around that sell used.Am in Ontario.
