I can't seem to figure out why it won't turn on when you turn the key for the 2-5 seconds like its suppose to, I have went ahead and replaced the oil temp sensor, the fan works when grounding it out to the motor and the oil light comes on, But does not for the key turn, everything seems to be working, went for the drive the fan comes on before the oil temp as it should i assume,fan doesn't seem to turn off though unless you turn the bike off, never over heated so the oil light never came on. 212F for the fan? and 300 or so for the light? maybe it doesn't for this model of bike no idea at this point, my 2003 honda 350 oil light comes on for 2-5 seconds on the key turn.
It is an old bike with alot of work done to it,new clutches, top end, replaced the ECM with another, Not exactly sure what is going on or if there is any issue, Fan does come on, maybe best to leave it alone. It was one of them odd bikes honda discontinued right away, it worked great for 22,000 before i went ahead and had all of its issues narrowed down. seems to be a great working bike otherwise then this little issue if its even worth fixing since its an old bike.
Anyways any suggestions are welcomed, thanks
