Hi guys I'm new I just joined the Honda club. I have a rancher 350 that's making noise I want to check the timing chain. Is it best to pull the rear end off to pull the engine cover or would I need to pull the whole engine. Looks like I need a special socket to get the rear frame off. Thanks for any help.
welcome to the forums. first, you need a 17mm allen wrench, ( this has been covered many times on here, a quick search would tell you this ), the motor does not have to come out to change the cam chain. drop the rear swing arm, then you can get the case off. you will need some yamabond or hondabond to seal that case back up, the pull starter calls for a gasket if i'm not mistaken ?.
Thank you shadetree. Yeah I ordered hondabond off eBay should be bear in a few days.
do down load the service manual from our site here !, it will pay for itself !. and your welcome :). oh, incase ya did not know ?, most Honda dealerships sells yamabond ( same thing as hondabond ).
