I am stuck. I have owed this ATV for six years and it has ran perfect since I rebuilt the top end when I first bought it. Had some carb trouble due to bad/old gas. Took it to a local small engine shop and had them rebuild the carb, now it runs normal without gas flowing out of the overflow like before. However, now it has an error code and only drives in the fail safe mode. Equivalent to first gear and sputters when put in reverse. So I do some digging around on here, find the repair manual and realize the system should have be re-initialized after the carb was taken off. So I read the instructions for how to do this and begin to attempt. The initial setting procedure states the shift indicator should display N or D or R, but mine just flashes "--" no matter what reset or diagnostic steps I try from the repair manual. Please help.
*Note: The "--" blinks 6 times and that code is the swash plate sensor. Should I replace or check connection before proceeding. The error code retrieval procedure was done by the shop and I haven't been able to get it to display anything else since then.
