when going to 3 gear 4x4 start blinking 2 times , manual says to check connector (3p/gray) front final clutch speed sensor, voltage between the Black/orange and Green (mine has Pink/green and Green) with switch on 9.90 volts while battery has over 12 volt I can not find short in wire where should I look next
