Not familiar with the specific ATV??
But if there is a carburetor and it is flooding fuel into the intake air box as described, I would assume that the carb. fuel(or float) bowl is overflowing due to a malfunction of a float bowl valve, float, etc.
You may try tapping on the bottom of the carb to temporarily correct it.
You may verify the fuel bowl theory, by shutting of the fuel supply at the tank and operate the motor and observe if this corrects the suspect overflow(manually open and re-close the supply from the tank to allow the bowl to fill but not overflow).
In any case and as someone previously suggested, the issue is in the carb.
But before anything else.....move the machine into a safe place and be careful!!
Hope this helps
