Okay I have a 03 rincon it won't move when I put it in gear esp or auto I just did a full top end rebuild I took it out for a break in ride it loaded up onto the trailer fine and when I got home nothing wouldn't move a inch any ideas plz and thank you
rincons are driven off oil pressure - there's a chance your oil pump chain fell off, you'll have to pull the front cover to inspect the chain/sprocket. or it could be that your oil pump failed-and/or your oil pump O-rings aren't sealing and are bleeding pressure off.
all of this will require tearing back into it. (you can also test oil pressure before disassembly, however with no drive, I'm sure you don't have any pressure)
