Leaks gas out of the overflow tube on the bottom of the bowl.
Had a friend rebuild the carb, still leaks. Replaced with new carb and didn't have much gas so I put in the little I had. Fuel lever on reserve and it started and ran great no leaks, used it 2 or 3 times for short drives in a 2 week period, no leaks. Wifey gets some fresh non ethanol gas so I put some in just until the fuel gauge started to register, maybe a half to 2/3 of a gallon. Turned fuel lever to on instead of reserved, took for a drive to bring garbage out. Parked and checked for leaks, none. 2 hours later I take the dogs out and smell gas as soon as I opened the door. Puddle of gas again leaking from overflow, turned fuel lever to off. Got up the the next AM and the gas had completely leaked out. How can it still leak if the fuel valve is off? Could the petcock (fuel valve) be bad? I did clean out the gas tank while my friend rebuilt the first carb, there was rust from the fuel gauge. I cleaned up the rust and replaced the screen/filter with a new one. Any ideas I am out of hair to pull out?
