Ok So first post,
I have a 2002 Rubicon TRX500FA which would not shift through the gears, and when I ran the codes I ended up getting a code 6. I replaced the angle sensor (new part tested good on an ohmmeter). Angle sensor was pre-loaded according to the manual.
Start-up the atv no longer flashing and continuous "N" appears on the screen. I start the set-up procedure idle for 30 seconds in neutral then roll forward 5 feet in Drive. Says to make sure continuous N changes to D. This doesn't happen ATV drives, but thinks its in neutral.
Go ahead with rest of procedure and shift motor runs after the up down up portion, but then the set-up fails at the very last second. and I get a constant blinking --. I believe this indicates failure of Initial set-up procedure.
turn off key and constant neutral light returns.
