Hello to all, New member,Trying to resurrect a 2002 TRX350FE2A. Just some background first.
I have a new battery. The clutch is adjusted. The meter is powered. All connectors have been cleaned and dielectric grease applied. The speedometer always reads 0mph. The gear indicator is always blank, except when you unplug the speed sensor. With the key on engine off, speed sensor unplugged, I can shift through the gears and R,N, & 1-5 all show on the meter. When you ride it slow it will shift fine, but if you ride it normal, shifting will lock up until the key is switched off and back on, then it will work again.
First tests: Speed sensor; measured voltage on the harness side between BL/BU+and G -.
Manual says I should read battery voltage. I am only reading a little over 4.69 vdc. Should I be reading more than 12 vdc on the harness side between BL/BU + and G - ???
With jumpers between the harness connector and the speed sensor connector, KOEO, I am measuring voltage between the PK/G + and G - reading 5.16 vdc constantly, while slowly turning the wheels. No pulse voltage. I have installed a NEW speed sensor and it tests the same.
Usually I can figure this stuff out but I don't have the experience with these.
I would appreciate your insight. :nerd
