Had an electrical fire in the wiring the other day while trail riding.
Under the fender above the right rear wheel. The fire was in the wiring above the electronic module mounted to the frame. The fire did not stop the engine, noticed smoke coming from under fender. Shut the engine off and disconnected battery. Then wiring changed from smoke to flames. Was towed off the trail.
So need to know what parts are available to fix the wiring harness.??
Any sources and ideas on what should be replaced be sides melted wires.
Is the complete rear wiring harness available?
What electronics should be replaced besides the module at the fire source??
Thank you in advance
Jim E
Maryland
Jim E
Maryland
