This has been a good atv replaced some normal things that wear. But a couple of weeks ago while riding it stopped shifting so I shut it off and within about fifteen minutes the battery went dead started checking things and found that if I unplugged the voltage regulator the battery drain stopped checked the alternator wires everything seems fine so I replaced the regulator everything is working fine now but the new regulator gets so hot that it will burn you if you touch it in sure this is not normal and is going to burn this one up I have checked the wiring according to the manual and the battery but can't find what's causing this issue everything seems fine has anyone else had this problem or have any suggestions I know the new regulator is not gonna last long getting that hot I have to be overlooking something I'm just not sure what any help would be much appreciated thanks in advance to anyone willing to help
