OK guys... my ole '02 sat up for 3 years and with new carb and links and hoses...SHE FIRED RIGHT UP and runs like a scalded dog! Gotto love Honda...But...alias...she has a NOSE DRIP of gasoline out the little hose off the carb. It looks like a 'pressure check' valve on the hose and it too is new. It did this last week at 1/2 tank of gas, so I filled her up and it stopped. But, went into shed this AM and there was the gasoline 'nose drip' again...at full tank. So...how do I repair this 'money in the dirt' issue? It was doing this with the OLD CARB but stopped 8 months ago when I slapped in the new carb kit. What is the issue? What is the repair? I can see the drip..drip...drip out of the hose and there are no other leaks anywhere...and..she still fires up and runs.. (can I just plug this hose and end the drips?) thanks in advance...
Nose Dive....
Total miles are: 1,172
Total hours: 270
Miles on new carb...ehhhh... 50 maybe...
There is a float in the carb. When the carb bowl gets full, the float goes up, and a needle on the front stops more fuel from flowing into the carb.
When you get crap in the carb, that needle doesn't seal with the seat, and you get a leak.
If you plug the drain line, the fuel has to go somewhere so it ends up in the crankcase (bad) or the airbox (still not good).
https://www.partzilla.com/catalog/honda/atv/2002/trx400fw-a-fourtrax-foreman/carburetor
Take the carb off, take the bowl (#5) off the bottom (4 screws). Take the float (#4) out (drive pivot pin out), take the float needle (#18) and lightly polish the tip with some 0000 steel wool.
Now look at the seat (where that needle goes) and put some polishing compound or even toothpaste on a qtip, put it in a drill, and use the end to polish the brass seat where the needle valve seats.
That should stop your drip.
i posted on 1st thread. before i realized, there was a 2nd thread, with the same subject. my mistake?????
Thanks man! Yea...on the OLD carb when I disassembled it...the PIN was actually STUCK in the recess... I had to use some WD 40...then carb cleaner to get it to budge.. BUT let it sit for 3 years with gas in the bike...that is what you get... I'll yank her out and do some polishing work as you suggest...
Thanks again buddy...
Nose Dive....
