I bought a very well abused 2002 350 ES 4x4. It needs about everything replaced. But specifically today I need help on...
1) One of the front axles/cv joints is totally junk. I watched videos and read up on removal but my axle shaft will not come out of the differential with some hard pulling like the guys in the videos. I feel like the next step is a pry bar but I don't want to do that without making sure there is not some kind of clip or something holding it in on a 2002 350?
2) There is nothing that I can see to turn the 4x4 on and off - the best I can tell it is full-time 4x4. I got it stuck in some snow in the yard and the front diff is definitely not doing anything in snow. So while I have it jacked up I tested its operation. If I gently rotate the front tire an inch forward or back until it "catches" in the transmission, I can see the front shaft from the engine to the front diff gently turning back and forth as I rotate the tire back and forth an inch or so. But as soon as I turn it beyond that point, the shaft from the engine to the front diff no longer moves, as if there is a clutch in the front diff allowing it to free-wheel. Does this mean that the front diff has a problem? I have the transmission in Neutral if that matters.
Thanks in advance for the help.
