I have an 01 recon and I think the bearings are bad in the axle. looking at the rear end, it is the left side of the axle that makes a grinding noise, opposite the break, when you spin the wheel. Im not sure what it is but was told that it might be the bearings? - any suggestions on what to do
Welcome to the forums. Yeah, it sounds like the bearings are out.
can you guys give me some basic directions to get started - Does the axle slide out once I take the locking nuts off and is there a specific way it should come out.
Remove the left hub and right hub, axle nuts, brakes and the axle knocks out the right side.
