I’ve had a clunking noise coming from my front differential for a while now, mostly when I come to a stop. Yesterday, I took the differential out to see what’s wrong and order replacement parts, but other than pinion gear having the most visible wear, I can’t figure out what I need to replace everything looks fine. Can someone with experience on this look at the photos and see if something is worn and should be replaced.
I replaced my front axles last year, the old ones had ripped boots and I thought that’s what was clunking but the clunking continued after replacing the axles.
2001 Rancher ES 4x4. The machine has been used for snow plowing most of it’s life, I thought maybe some of the parts inside the differential have worn, so I decided to take it apart and see.
Thanks.
Thanks.
