I mistakenly thought the ES power control motor was the starter (I know, I know), so I could tap it and get the engine to turn over. Well, that got harder and harder to do, so I hit it harder and harder. Turns out I shattered one of the internal magnets and it was completely locked up. (That's when I figured out it wasn't the starter and bought a new starter) I bought a new OEM one from Partzilla and put everything back together I had taken off. (reduction gears, angle sensor, etc, the items contained in the front plate). That was the only thing I physically damaged, so I assumed it would just fire right back up (electric shifted fine before). It's really odd, I can't get any error codes (holding both buttons down, turn the key on, remove fingers in two seconds, then hold them both back down again for three seconds). All I get is a solid neutral. With the control motor out, I can manually shift the bike fine to R, 1 - 5 and it reads on the header. When I install the motor, I can FORCE a shift, but it feels wrong.
I tried to reset it by holding both buttons, turning it on, immediately removing and pushing up, down, up. I can hear a tiny bit of noise coming from the motor, but doesn't travel enough to make a shift. One time when I disconnected everything and put it back together, I had good power at the buttons (more whirring of the motor), but it wasn't changing the gears. That worked for about 10 pushes then it's like the power went down. I'm completely charging the battery but it feels like I have a drain somewhere. I'm about 85% of the way through the harness verifying conductivity of each wire, but even if I get that, I still can't get the thing to talk to the tranny.
Seasoned ATV'ers, PLEASE HELP (TRX350TE)
