1 - 2 of 2 Posts
Stuck in reverse no matter what gear its in on shifter. what is the fix
Operating the shift lever should link up to rotate a shaft going into the motor. You need to check out that system and make sure that everything is connected and that moving the shift lever creates a respective rotation of the input shaft. If it doesn't find where it is disconnected. Diagram: https://www.partzilla.com/catalog/honda/atv/2001/trx500fa-a-fourtrax-foreman-rubicon/select-lever
If all is good there, then you may have an internal problem. And get a copy of your service manual here: http://www.hondaatvforums.net/forum...ads.html#/forumsite/21330/topics/50817?page=1
1 - 2 of 2 Posts
