Not sure where to begin.. This weekend was the first time I was able to actually ride my four wheeler and I mean ride not just putting around my yard. It did fine the first few hours of riding. 5th gear no problem, reverse was fine, starting up was fine, idling was fine. Just before I was gonna wrap it up and load it up it started to die on me. Now whenever I start it with the choke on it will idle for a bit then die, as well as if I have the choke half open or fully open it will die. If the choke is fully open I can slowly idle it up as high as it will go but if I gun it, it will bog down and die. If the choke is half open it will do the same but not as much as if the choke is fully open. I have went through the carburetor cleaned rebuilt air hosed everything out I could and gave it fresh new gas. And it’s still doing the same thing. I also noticed it started tapping a little louder after driving a bit. But it didn’t increase in noise while going faster or reving it up. So I checked the valves and they are still set at the manual settings. I’m kinda at a loss here.. do I need to dig a little deeper in the motor? Is it something simple I’m just over thinking or looking? Idk. Sorry if I’ve left something out. I’d appreciate any and all the help I can get!!
