Have you followed the troubleshooting section in the ES chapter of the service manual? Since the '01 model doesn't store trouble codes, that's about all you can do........follow the troubleshooting chart and try to pinpoint the problem.
it really does not matter who you buy those from..either way..i can almost bet you..one of them will have to order it ?..something like that..most times wont be in stock..but..if i were you..i would get that part from a dealer.Thanks for advise guys! If I want to buy a new angle sensor, any good options other than local dealer?
your welcomeThanks, will give it go on the weekend.
Yeah, turning the key off and back on, resets the ECU.There is a cool trick I learned while messing around with it one day that works on mine and might work for you as well:icon_ rasta:. whenever it want change and the display starts flashing turn your key off and back on real fast, so that it keeps the motor running and it resets the sensor some how and wala'!!
