Hey folks, real newbie here. I've taken about the front of my second- or third-hand 450ES and found a destroyed rubber bushing in the suspension:
150563
Ordered a repair kit:
150562
but found it doesn't match up. I went and looked for the proper part and can't seem to find it. Now I'm putting two and two together and thinking that there might be a lift kit or something in play here, as visible in the first picture.
Any thoughts or assistance identifying what I need would be appreciated.
yes it looks like you have a lift kit on your atv. and it also looks like you bought '' all balls '' junk ?..lol. that bushing is your shock bushing, from memory ?, that rubber bushing does NOT come in any rebuild kits ?, its part of the shock. you need this ---> Honda 52489-HF7-003 - BUSH, DAMPER | Partzilla.com .
and that damper is pressed into that shock !. you will need a press to press the new damper/bushing back in the end of your shock.
