First thread started (second post).
Backstory:
Bought a 2000 Foreman 450ES that had been sitting for several years. Old man said that it was running when parked. Went to pull the starter cord and it wouldn't budge (in neutral). Put it in gear and tried to pull it with my vehicle and the tires didn't turn. In neutral it rolls. He wanted $500 for it, but talked him down to $800 if he would throw in a rancher 350 he had that was running decent (has its own issues). Got them both on the trailer and headed 2 hrs home.
Wrenching:
Wanted to see if the engine would turn so pulled the starter cord again...no dice. Poured some mystery oil (MMO) in the cylinder and let it sit overnight. Still wouldn't pull so decided to see if I could push the piston down with compressed air and it went down until the intake valve actuated and started blowing back through the carb. This is positive progress...right?
Then tried to pull the front diff, but when I got to the rear lower bolt it backed out 1/32" and then stopped and would not budge. Put impact with 120 psi to it and it didn't move. Put a breaker bar with a 4' cheater on it and broke a socket and a socket extension and then rounded the bolt (dang 12 pt sockets). Switched to the rear axle to make some progress and got the rear axle out from under it. What a godawful mess! water invaded driveshaft tube and looks like it was driven hard afterwards. Oh yeah, the swingarm is sitting in there slightly cockeyed so it will need new bearings, seals, etc. and the rear output driveshaft boot has collected a metal crescent (one of the driveshaft housing bearings I think). Have to build a locknut removal socket before I can diagnose this issue more.
This is where it sits currently. Been working other projects, but saw some really good posts on here and decided to see if anyone had ideas on the motor not turning. I really don't want it to be a broken crank, but if it is I found a youtube video that shows a guy rebuilding his atv motor...what can go wrong?
I have a digital copy of the repair manual for this model so a complete rebuild may be in order.
What do you guys think? Is there anything else I can do except pull the motor and start tearing into it?
Thank you for your help,
XJ
Backstory:
Wrenching:
XJ
