I have a 2000 TRX350FM that blows the main fuse even with the key off. I unplugged the rectifier and the fuse doesn't blow. I assumed it's old and probably has an internal short so I replaced the rectifier. Even with the new rectifier the main fuse blows. I checked the wiring from the rectifier plug up to the ignition switch connector and didn't find any wires that would be shorting out. I am hoping someone can point me in the right direction to check now.
Thanks!
Thanks!
