Folks
I am having an issue with a driven pulley removal.
Its a 2000 350 rancher trx-fe 4x4 es.
I followed in the manual and I --
removed the engine from the frame
removed the recall starter
it says, "hold the recoil starter driven pulley using a screwdriver to scotch the thing" and loosen the bolt.
That sucker is on there very tight - I mean I cranked at 120 ft pounds 3' long ratchet torque wrench and cant get it off.
I used an 3/4" impact with 17mm impact socket at 155LBS on compressor and nothing broke loose.
I used a breaker bar and a pvc pipe to get leverage and nothing broke loose.
Now i have been doing lefty loosy.
Is this thing opposite to get it off or --as in, turn to right to loosen? http://www.hondaatvforums.net/forums/images/smilies2/blink.gif
I am 270 LBS and 6'3" and can bench at least 250lbs, this little boy is sweating trying to get it off.
any ideas appreciated as I don't want to break this off in the crankshaft.
Just want to remove this side to change out the cam shaft and chain.
thanks again folks !!
