I have a 2000 Rancher that is not charging. I have checked my stator voltage and is around 18vac at idle and about 40vac when revved. I have checked check the rectifier/regulator and it is putting out 14.05vdc. I also checked all fuses by the battery. At the battery I am only getting the battery voltage of 12.39vdc. I can follow the electrical schematic and pick up the 14.05vdc in several other components. I.E. ignition switch, Aux plug, fuse block, etc... I tried a jumper wire from one of those wires back to the battery + and the voltage then drops to the 12.39vdc. Can anyone help me out here? Thanks
