Shift troubles no code or blinking. Turn key on the nuetural light comes on and so does reverse light. Its in neutural because i can push it freely. All i did was put new carb on it road it and put in garage. Now troubles
Electric shift? OEM carb?Shift troubles no code or blinking. Turn key on the nuetural light comes on and so does reverse light. Its in neutural because i can push it freely. All i did was put new carb on it road it and put in garage. Now troubles
Oem carb with heater plug is correct.theres no blinks on screen and reverse light on at same time. I had just road it before problem occurred. I have honda repair manual. Says ecu will deactivate es if detects problem. The rancher was at complete stop when problem occurredElectric shift? OEM carb?
Did you inspect the gear position cabling?
Did it have a carb heater on it and if so what did you do with the cable?
Check the service manual and parts links in my signature block below
