Hello Everyone,
I am new here. I have a rancher that I am trying to get up and running again. It was mine when I was younger, and my grandfather used it for a while until it quit running about 2 years ago. He got to the point he was going to either have one of us come get it or sell it, so I decided to go pick it up and get it running.
I believe it is a 2000 trx. It is the 2 wheel drive version with the manual foot shift. Not sure where to look to verify the year or exact model, but if anyone does know I will be glad to look it up.
I have cleaned the fuel system and the carburetor, and have replaced the spark plug but I still am not getting a spark. I checked the kill switch and it seems like it may not be working. I will replace it, but want to make sure I can get the atv running before I spend that extra money. Do I need to wire the two wire's together or not to trick the engine into thinking it is in the run position?
Also, I went ahead and checked the ignition coil and it seems to be giving about 3.5k ohms. Is the coil bad, or is this a normal reading? Seems low to me but just wanted to double check.
Thanks for your help guys. First project like this and wanted to get as much help as I could along the way.
- Caleb
- Caleb
