Hello all, i need help. My 350 rancher speedometer is water logged. Honda part number is 37200-hn5-a12(4x4) and has been on back order for months. Would anyone know what the difference between the 37200-hn4-a12 (2x4) would be
The 14P meter connector is wired differently in 2003 due to an upgraded ECM that has more wires going to it. Check the 2003 diagram again... see the W/P wire (3rd from bottom of the plug) going to the ECM?...The 2003 uses the same 14p plug and it also appears that the connector is keyed the same i hope that the run the same voltage.
someone should tell that seller to remove his ad !!. no freaking way they cost 1k !!!..lol. i've bought them in the past many times, and the most i've seen them is at 200 bucks ( give or take ).Good news and bad news here’s one
You could try to source a used one
If I had to guess the seller put that price on there to keep from having to pull the ad, and knowing that the part is on backorder at the moment.Good news and bad news here’s one
