I have a 2000 450 ES and a no shift issue. It got stuck in 1st gear so we was rocking it as I was manually shifting to neutral. When doing so, I heard a pop and the shifter just has free play and I can hear the shift motor work as I work the shift arm. Took the front cover off and found the Sub gearshift arm tip broken. 17 in attached schematic, I really thought it would be 16 gearshift A arm from my searching.
So a couple questions. First, when I took the front cover off there was a flat washer that I have no idea where it came from, it was just laying lose on one of the clutch drums. I haven't been able to find it in the manual or parts diagram. Any idea where it goes when I put the cover back together?
Second, I don't see #16 gearshift A arm from what I have read. It is behind the front cover with the shift drum. Is it in the front or rear case?
Would the broken sub gearshift arm cause my problem or do I need to look deeper?
This has been cross posted on another forum. I haven't received any help and I need to get it fixed.
Thank you for any help you can give.
Jeff
Jeff
