Starter is good / Seleniod new / Starter switch is fine / Everything seems to check out but it don't start. Have to jump the selenoid to start it. Whats WRONG?
first..check to make sure your solenoid is pluged in ??..check all your ground wires..make sure your getting good ground..if your solenoid is good..your start button is good..and your starter is good..it should crank over. if it doesn't..then you have a bad connection somehwere...did you make sure your ground wire is making a good connection ?..it should be bolted through a bolt..through the starter ..into the engine...check all this..somehwere between your battery..to solenoid to starter is a loose wire for ground. added : check your fuses !Starter is good / Seleniod new / Starter switch is fine / Everything seems to check out but it don't start. Have to jump the selenoid to start it. Whats WRONG?
