New member, recently swapped for this rancher, electric shift does not work but emergency manual shift does with no problems. Following troubleshooting in service manual. First step says, turn ign. off, disconnect large ecu connector and check voltage from black/green wire to ground. should be 11 volts minimum. I did and had no voltage. I can read wiring diagrams and do everyday at work in the hvac industry. According to diagram I should not have voltage unless the ign. switch is on. I did ohm my wires and they have continuity where they should. I went through step 2 with no problems and at step 3 found my angle sensor bad, open circuit in either position. Am I missing something here. Sorry so long but did not want to leave anything out, any help is greatly appreciated.
