and 1 more question ive got these denso iridium power spark plugs IK20 5304 they where for a neon. here is the Product Description
DENSO Iridium Spark Plug, 14mm Thread, 19mm (3/4") Reach, 5/8" (16mm) Hex Size, Gasket Seat, Resistor, Removable Terminal, ISO height, 0.4mm Iridium Center Electrode, Tapered Cut U-groove Ground Electrode, .044" (1.1mm) Gap, Heat Range 20
ok now heres the description for the DPR8EIX-9 Laser Irodium
Extreme Long Life Laser Iridium Plug, 14mm Thread, 19mm (3/4") Reach, 5/8" (16mm) Hex Size, Gasket Seat, Resistor, Projected Tip, Solid Terminal, Iridium Tipped Fine Wire Center Electrode with Platinum Tipped Tapered Cut Ground Electrode, .044" (1.1mm) Gap, Heat Range 5
they seem to be the same thing to me other than the heat range? the one for car is heat range 20 and the one for atv is heat range 5? will it work in my atv? whats the heat range thing about?
