1 - 10 of 10 Posts
I'm about to do the first oil change on my bike since I bought it a year ago.Are the weights and oils I've selected correct or what do I need?Appreciate any help
Sent from my SAMSUNG-SM-G891A using Tapatalk
10w-30 or 10w-40 for the motor, MAKE SURE ITS RATED FOR WET-CLUTCH ENGINES !!!, such as motorcycles, atvs, atcs. all of these use the engine oil for not just the main part of the motor ?, but trannies too !. DO NOT USE AUTOMOTIVE OIL !!!!!!! ( oil made for trucks-cars ). as for the front and rear differentials ?, I use 80w-90 hybrid gear oil. you can also use this grade in the transfer case, or use plain motor oil that is made for cars and trucks, but I use the 80w-90 gear oil in the transfer case ( this is the two large gears at the front of the engine ) if its 4wd ?.
Reactions: hudson85
Reactions: hudson85
2.4 US quart engine oil w filter change
Plus you will need 200 cc in gear case oil same as engine oil
Did both diffwith 1 qt 80w90 hypoid.
Check yer manual I think yer short a quart of engine oil
I would but dont have a manuel which is why I'm asking
you can download the service manual from our site here, its free !.
Reactions: hudson85
Where is it on the sight,I'm on tapatalk and haven't seen it
Reactions: hudson85
The links are in my sig block ����������������������������
1 - 10 of 10 Posts
