I just purchased a 1999 Recon with hopes to use it on some land we are buying. In the process of replacing the rear axle seals and bearings, I discovered the rear pinion bearing is shot. (I had to remove the diff to gain access to drive the exploded axle bearings out.) I'm really trying to spend as little money as possible on this almost 20 yr old bike, but I hate to not repair it properly.
I've found a 2011 and 2012 Recon diffs for sale. Does anyone know if as long as I buy the axle shaft for the newer models, will they be bolt on replacements? Thanks.
Doug
Doug
