start with down loading service manual , then start reading. check compression, timing , check/adjust valves...all this is where I would start.
The manual will show the correct spark plug just in case you got the wrong one
Mist importantly you ought to rebuild yourOEM carb cuz I don’t think you bought a new oem carb
Aftermarket carbs do not fit right on these machines
Search out the carb sticky and TRX300 rebuild threads. These are EASY to rebuild
how long ya had it?
