I will try that if i can figure out how to drain itFirst thing I would do is drain the fluid from the rear end and see what it looks like. That may be your first clue. You can take a magnet and dip it in the oil you drain and see if there are metal shavings in it. Thats where I would start, its cheap, easy, and could possibly tell you if the problem is in the diff or the brakes.
Oh and BTW, Welcome to the forums! There are several VERY knowledgeable people here that will chime in with way more help than I can provide you. :wink:
take off the left rear tire (its easier that way) on the left side of the differential at the bottom there is a small (maybe 10mm) plug don't lose the washer! remove it then on the back of the diff there is a larger plug you can't miss it take it off and fill it back up with 80/90 gear lube.I will try that if i can figure out how to drain itFirst thing I would do is drain the fluid from the rear end and see what it looks like. That may be your first clue. You can take a magnet and dip it in the oil you drain and see if there are metal shavings in it. Thats where I would start, its cheap, easy, and could possibly tell you if the problem is in the diff or the brakes.
If your rear diff is making a noise and you find metal shavings in it, you will need to pull your diff off and take it apart and inspect the gears. These are bad for the ring and pinion gears going out. It's usually caused by the axle bearings getting bad and still riding the 4-wheeler. The movement of the axle causes the ring and pinion gears to come out of alignment and not mesh properly. If this is what happened, your axle bearings will probably be bad, too, unless someone has recently replaced them and didn't replace the ring and pinion gears. On these models, it is important to check for axle bearing wear often and at the first signs of movement, replace the axle bearings. This will usually keep you from having any gear problems. Also, check the gear oil often, as well, because mud and water in the diff will also cause the gears and bearings to go bad.thanks guys i will try both of these. What do you suggest if i find metal shavings in the rear end?
What kind of oil should i use and can i just get from a auto parts store?
also how much should be used?
Ouch!!!Sorry to hear that.Honda shop says that i need a new rear diff. bearing and a new axle bearing and they will also have to turn the spindle. Estimated cost $600
